I realize that setting up pbuilder requires root privileges, but does each invocation really require root privileges?
Is there any way of running pbuilder as a standard user?
Nathan Osman
  • 32,495
Yes, copied from: pbuilder.
It is possible to use user-mode-linux by invoking pbuilder-user-mode-linux instead of pbuilder. pbuilder-user-mode-linux doesn't require root privileges, and it uses the copy-on-write (COW) disk access method of User-mode-linux which typically makes it much faster than the traditional pbuilder.
User-mode-linux is a somewhat less proven platform than the standard Unix tools which pbuilder relies on (chroot, tar, and gzip) but mature enough to support pbuilder-user-mode-linux since its version 0.59. And since then, pbuilder-user-mode-linux has seen a rapid evolution.
The configuration of pbuilder-user-mode-linux goes in three steps:
  1. Configuration of user-mode-linux
    user-mode-linux isn't completely trivial to set up. It would probably be useful to acquaint yourself with it a bit before attempting to use rootstrap or pbuilder-user-mode-linux. For details, read /usr/share/doc/uml-utilities/README.Debian and the user-mode-linux documentation. (It's in a separate package, user-mode-linux-doc.)
    user-mode-linux requires the user to be in the uml-net group in order to configure the network unless you are using slirp.
    If you compile your own kernel, you may want to verify that you enable TUN/TAP support, and you might want to consider the SKAS patch.
  2. Configuration of rootstrap
    rootstrap is a wrapper around debootstrap. It creates a Debian disk image for use with UML. To configure rootstrap, there are several requirements.
    • Install the rootstrap package.
    • TUN/TAP only: add the user to the uml-net group to allow access to the network adduser dancer uml-net
    • TUN/TAP only: Check that the kernel supports the TUN/TAP interface, or recompile the kernel if necessary.
    • Set up /etc/rootstrap/rootstrap.conf. For example, if the current host is 192.168.1.2, changing following entries to something like this seems to work.
      transport=tuntap
      interface=eth0
      gateway=192.168.1.1
      mirror=http://192.168.1.2:8081/debian
      host=192.168.1.198
      uml=192.168.1.199
      netmask=255.255.255.0
    Some experimentation with configuration and running rootstrap ~/test.uml to actually test it would be handy.
    Using slirp requires less configuration. The default configuration comes with a working example.
  3. Configuration of pbuilder-uml
    The following needs to happen:
    • Install the pbuilder-uml package.
    • Set up the configuration file /etc/pbuilder/pbuilder-uml.conf in the following manner. It will be different for slirp.
      MY_ETH0=tuntap,,,192.168.1.198
      UML_IP=192.168.1.199
      UML_NETMASK=255.255.255.0
      UML_NETWORK=192.168.1.0
      UML_BROADCAST=255.255.255.255
      UML_GATEWAY=192.168.1.1
      PBUILDER_UML_IMAGE="/home/dancer/uml-image"
    • It needs to match the rootstrap configuration.
    • Make sure BUILDPLACE is writable by the user. Change BUILDPLACE in the configuration file to a place where the user has access.
    • Run pbuilder-user-mode-linux create --distribution sid to create the image.
    • Try running pbuilder-user-mode-linux build.
Extra comments in the link:
pbuilder-user-mode-linux emulates most of pbuilder, but there are some differences.
  • pbuilder-user-mode-linux does not support all options of pbuilder properly yet. This is a problem, and will be addressed as specific areas are discovered.
  • /tmp is handled differently inside pbuilder-user-mode-linux. In pbuilder-user-mode-linux, /tmp is mounted as tmpfs inside UML, so accessing files under /tmp from outside user-mode-linux does not work. It affects options like --configfile, and when trying to build packages placed under /tmp.
To run pbuilder-user-mode-linux in parallel on a system, there are a few things to bear in mind.
  • The create and update methods must not be run when a build is in progress, or the COW file will be invalidated.
  • If you are not using slirp, user-mode-linux processes which are running in parallel need to have different IP addresses. Just trying to run the pbuilder-user-mode-linux several times will result in failure to access the network. But something like the following will work:
untested
Rinzwind
  • 309,379
