If I try to run sudo apt-get install python-box2d I get this nonsensical error message:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
libcv-dev : Depends: libopencv-core-dev but it is not going to be installed
libcvaux-dev : Depends: libopencv-core-dev but it is not going to be installed
libopencv-calib3d-dev : Depends: libopencv-calib3d2.3 (= 2.3.1-7) but it is not going to be installed
libopencv-contrib-dev : Depends: libopencv-contrib2.3 (= 2.3.1-7) but it is not going to be installed
libopencv-features2d-dev : Depends: libopencv-features2d2.3 (= 2.3.1-7) but it is not going to be installed
libopencv-flann-dev : Depends: libopencv-core-dev (= 2.3.1-7) but it is not going to be installed
Depends: libopencv-flann2.3 (= 2.3.1-7) but it is not going to be installed
libopencv-highgui-dev : Depends: libopencv-highgui2.3 (= 2.3.1-7) but it is not going to be installed
libopencv-imgproc-dev : Depends: libopencv-core-dev (= 2.3.1-7) but it is not going to be installed
Depends: libopencv-imgproc2.3 (= 2.3.1-7) but it is not going to be installed
libopencv-legacy-dev : Depends: libopencv-legacy2.3 (= 2.3.1-7) but it is not going to be installed
libopencv-ml-dev : Depends: libopencv-core-dev (= 2.3.1-7) but it is not going to be installed
Depends: libopencv-ml2.3 (= 2.3.1-7) but it is not going to be installed
libopencv-objdetect-dev : Depends: libopencv-objdetect2.3 (= 2.3.1-7) but it is not going to be installed
libopencv-video-dev : Depends: libopencv-video2.3 (= 2.3.1-7) but it is not going to be installed
libplayerdrivers3.0 : Depends: libopencv-core2.3 but it is not going to be installed
Depends: libopencv-highgui2.3 but it is not going to be installed
Depends: libopencv-imgproc2.3 but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
If I try to run the suggested sudo apt-get -f install, it tries to install all the above, but they all fail with errors like:
dpkg: error processing /var/cache/apt/archives/libopencv-video2.3_2.3.1-7_amd64.deb (--unpack):
trying to overwrite '/usr/lib/libopencv_video.so.2.3.1', which is also in package libopencv2.3 2.3.1+svn6514+branch23-12~oneiric
No apport report written because MaxReports is reached already
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
What's going on here? As far as I know, Box2D doesn't use any of these OpenCV packages (it's a 2D physics library whereas OpenCV is a vision-processing library), and even if it did, why are all the packages broken?
