I have just started (as in 30 minutes ago) to use Ubuntu 12.04 (all my previous experience is with windows) and I just started to learn how to program a couple of weeks ago so this is probably a really beginner question. I have also posted this on the Unix and Linux Stack Exchange, but I thought maybe people around here would be able to help as well
I am trying to install python 3.2, and to get setuptools and pip in python 3.2. Everything seems to work right in python 2.7. However when I try to install setuptools using this code wget https://bootstrap.pypa.io/ez_setup.py -O - | sudo python3.2 I get the following error
Extracting in /tmp/tmpcwnav_
Traceback (most recent call last):
File "<stdin>", line 332, in <module>
File "<stdin>", line 329, in main
File "<stdin>", line 51, in _install
File "/usr/local/lib/python3.2/contextlib.py", line 28, in __enter__
return next(self.gen)
File "<stdin>", line 101, in archive_context
File "/usr/local/lib/python3.2/zipfile.py", line 1004, in extractall
self.extract(zipinfo, path, pwd)
File "/usr/local/lib/python3.2/zipfile.py", line 992, in extract
return self._extract_member(member, path, pwd)
File "/usr/local/lib/python3.2/zipfile.py", line 1035, in _extract_member
source = self.open(member, pwd=pwd)
File "/usr/local/lib/python3.2/zipfile.py", line 978, in open
close_fileobj=not self._filePassed)
File "/usr/local/lib/python3.2/zipfile.py", line 487, in __init__
self._decompressor = zlib.decompressobj(-15)
AttributeError: 'NoneType' object has no attribute 'decompressobj'
Based on some googling, it looks like I am getting the problem because zlib has not been installed. I do not have this problem when trying to install setuptools for python 2.7. I went into python 3.2 and tried to import zlib and got an error message when I tried that. I also tried to do 'sudo apt-get install zliband got the error messageE: Unable to locate package zlib. I did not get error messages when I triedsudo apt-get install zlib1gor sudo apt-get install zlib1g-dev I really have no idea what's going on. How do I get zlib for python 3.2 (or otherwise fix this problem?)
