I'm trying to mount a remote WebDAV (OwnCloud) using https on my Ubuntu 12.04 machine.
I run this command and it prompts me for a username and password
sudo mount -t davfs -o uid=ne,gid=users https://example/owncloud/remote.php/webdav/ /mount/remote
I then get the error
/sbin/mount.davfs: Mounting failed. SSL handshake failed: SSL error: sslv3 alert handshake failure
Other machines (including Android) are able to connect to the WebDAVS correctly.
How can I prevent this error? The certificate is signed by CloudFlare, if that makes a difference - but that doesn't seem to cause a problem for any other systems accessing the OwnCloud instance.
Running curl -v https://example.com everything seems fine
* About to connect() to example.com port 443 (#0)
* Trying 104.28.29.14... connected
* successfully set certificate verify locations:
* CAfile: none
CApath: /etc/ssl/certs
* SSLv3, TLS handshake, Client hello (1):
* SSLv3, TLS handshake, Server hello (2):
* SSLv3, TLS handshake, CERT (11):
* SSLv3, TLS handshake, Server key exchange (12):
* SSLv3, TLS handshake, Server finished (14):
* SSLv3, TLS handshake, Client key exchange (16):
* SSLv3, TLS change cipher, Client hello (1):
* SSLv3, TLS handshake, Finished (20):
* SSL connection using ECDHE-ECDSA-AES128-SHA
* Server certificate:
* subject: OU=Domain Control Validated; OU=PositiveSSL Multi-Domain; CN=sni29581.cloudflaressl.com
* start date: 2014-10-26 00:00:00 GMT
* expire date: 2015-09-30 23:59:59 GMT
* subjectAltName: example.com matched
* issuer: C=GB; ST=Greater Manchester; L=Salford; O=COMODO CA Limited; CN=COMODO ECC Domain Validation Secure Server CA 2
* SSL certificate verify ok.
> GET / HTTP/1.1
> User-Agent: curl/7.22.0 (x86_64-pc-linux-gnu) libcurl/7.22.0 OpenSSL/1.0.1 zlib/1.2.3.4 libidn/1.23 librtmp/2.3
> Host: example.com
> Accept: */*
< HTTP/1.1 302 Moved Temporarily
< Server: cloudflare-nginx
< Date: Mon, 27 Oct 2014 11:30:08 GMT
< Content-Type: text/html
< Transfer-Encoding: chunked
< Connection: keep-alive
< Set-Cookie: __cfduid=da7fc86a1e00780f7eea162120e2c4fe51414409408265; expires=Mon, 23-Dec-2019 23:50:00 GMT; path=/; domain=.example.com; HttpOnly
< Set-Cookie: DYNSRV=lin194; path=/
< CF-RAY: 17fe8f51aaa71365-LHR
* Connection #0 to host example.com left intact
* Closing connection #0
* SSLv3, TLS alert, Client hello (1):
I've also tried openssl s_client -host example.com -port 443 but that gives me Verify return code: 20 (unable to get local issuer certificate)
CONNECTED(00000003)
depth=1 C = BE, O = GlobalSign nv-sa, CN = GlobalSign Organization Validation CA - G2
verify error:num=20:unable to get local issuer certificate
verify return:0
Certificate chain
0 s:/C=US/ST=CA/L=San Francisco/O=CloudFlare, Inc./CN=ssl2000.cloudflare.com
i:/C=BE/O=GlobalSign nv-sa/CN=GlobalSign Organization Validation CA - G2
1 s:/C=BE/O=GlobalSign nv-sa/CN=GlobalSign Organization Validation CA - G2
i:/C=BE/O=GlobalSign nv-sa/OU=Root CA/CN=GlobalSign Root CA
Server certificate
-----BEGIN CERTIFICATE-----
(truncated)
bJLtKDaYbNmULxY=
-----END CERTIFICATE-----
subject=/C=US/ST=CA/L=San Francisco/O=CloudFlare, Inc./CN=ssl2000.cloudflare.com
issuer=/C=BE/O=GlobalSign nv-sa/CN=GlobalSign Organization Validation CA - G2
No client certificate CA names sent
SSL handshake has read 3158 bytes and written 363 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES128-SHA
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
SSL-Session:
Protocol : TLSv1.1
Cipher : ECDHE-RSA-AES128-SHA
Session-ID: EAC9072E6FFBD3E7AEA20B6C4D57F229DCC887CFAB08C2D47C0A546318A794E0
Session-ID-ctx:
Master-Key: 50ED2846908537665D348FCB07BB69ACEAD182F062F8235E5C7ED4958B4D446D70701E4C6876DE2DA06322BA090C46D5
Key-Arg : None
PSK identity: None
PSK identity hint: None
SRP username: None
TLS session ticket lifetime hint: 64800 (seconds)
TLS session ticket:
0000 - f1 98 d3 dc 67 02 22 1f-24 88 b7 dc 1c 1a 13 6a ....g.".$......j
(truncated)
Start Time: 1414409459
Timeout : 300 (sec)
I've tried updating to the latest libneon but that hasn't made a difference.
Update
Since upgrading to the latest OpenSSL, I now get a different error
SSL handshake failed: SSL alert received: Handshake failed
As suggested elsewhere, running openssl s_client -host example.com -port 443 -ssl3 returns:
Verify return code: 0 (ok)
I've compiled and installed libneon 30.1
./configure --prefix=/usr --enable-shared --with-ssl=openssl --disable-static
but the error persists.
