When trying to install some applications via Ubuntu software centre I am getting the error:
cannot install libfreetype6:i386
So I tried to install it via terminal, and got this result:
bfalcon@lappy:~$ sudo apt-get install libfreetype6:i386
Reading package lists... Done
Building dependency tree
gnome-keyring : Depends: gcr (>= 3.4) but it is not going to be installed
indicator-bluetooth : Depends: unity-control-center but it is not going to be installed or
                               gnome-control-center but it is not going to be installed or
                            ubuntu-system-settings but it is not going to be installed
                   Depends: gnome-bluetooth but it is not going to be installed or
indicator-network : Depends: unity8 (>= 8.00+14.10.20140806) but it is not going to be installed
libfreetype6:i386 : Depends: libpng12-0:i386 (>= 1.2.13-4) but it is not going to be installed
qtcontact5-galera : Depends: address-book-service (= 0.1.1+14.10.20140930-0ubuntu1) but it is not going to be installed
signon-ui : Depends: signon-ui-x11 but it is not going to be installed or
                  ubuntu-system-settings-online-accounts (>= 0.4) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I have tried a searching around a bit, but haven't come up with any solutions.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
JimmyB
  • 61
Try running this command to install all of the dependencies.
sudo apt-get install unity-control-center gnome-control-center ubuntu-system-settings gnome-bluetooth unity8 ubuntu-system-settings-online-accounts libpng12-0:i386 address-book-service
marisusis
  • 360
