I'm using cmus to listen to music now.One problem is that I couldn't close the interface while listening, i.e. keep it running background.The raw '&' doesn't work.I know moc(p) has the function,just pressing 'q', is there a similar way for cmus?
Asked
Active
Viewed 6,253 times
I've written a guide explaining how to use a bash script combined with a rebinding of the q key to have very comfortable detaching/reattaching with cmus, see https://github.com/cmus/cmus/wiki/detachable-cmus
Please tell me if this is good enough, since implementing this in cmus would be a lot of work :-).
Note: For the above solution to work the screen command must be installed: sudo apt-get install screen
This is how I work with cmus :
I run cmus manually on tty1 (Ctrl+Alt+F1) every time I login to my computer.
I control cmus from my gnome terminal using cmus-remote commands (look at manpage of cmus-remote.
That way you can exit the terminal any time you want and still have cmus running in tty1.
Kevin Bowen
- 20,055
- 57
- 82
- 84
gourgi
- 5,398
