17
I have a fresh install of Lubuntu and would like to install packages from a given list, without having to type sudo apt-get install package_name. Is it possible?
I'm not talking about the post-install scripts, that is something entirely different.
syntagma
  • 589
  • 15
If you have file (say pkglist) which contains list of packages to be installed like:
pkg1
pkg2
pkg3
or
pkg1 pkg2 pkg3
Then you can install those packages with apt by any of the following commands:
  1. sudo apt-get install $(cat pkglist)
  2. xargs sudo apt-get install < pkglist
  3. for i in $(cat pkglist); do sudo apt-get install $i; done
3rd one is recommended as it does work even if some pkgs are not found in the repository whereas 1st two would fail to install the available packages as addressed in this comment
For more information on apt-get install visit man apt-get install section.
Pandya
  • 37,289
Yep, just list all packages in a line separated by a space. e.g.
sudo apt-get install package_name1 package_name2 package_name3 package_name4
Sparhawk
  • 6,969
Put all the package names into a file (one package name for each line). And then run the below command to install the given packages automatically.
while read -r line; do sudo apt-get -y install "$line"; done < /path/to/the/packages/file
Example:
$ cat file
vlc
firefox
$ while read -r line; do sudo apt-get install "$line"; done < file
[sudo] password for avinash:
Reading package lists... Done
Building dependency tree
vlc is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 499 not upgraded.
Suggested packages:
  ttf-lyx
The following packages will be upgraded:
  firefox
1 upgraded, 0 newly installed, 0 to remove and 498 not upgraded.
Need to get 35.8 MB of archives.
After this operation, 24.3 MB of additional disk space will be used.
Get:1 http://ftp.cuhk.edu.hk/pub/Linux/ubuntu/ trusty-updates/main firefox amd64 33.0+build2-0ubuntu0.14.04.1 [35.8 MB]
0% [1 firefox 67.0 kB/35.8 MB 0%]                           10.4 kB/s 57min 16s^
Avinash Raj
  • 80,446
