Before I get started, yes I have googled this problem LOL, this one seems to be the one that works: 13.10 suspend kills wifi connection
The code that helps alot of people is this:
[CODE]sudo touch /etc/pm/sleep.d/wakenet.sh
sudo chmod +x /etc/pm/sleep.d/wakenet.sh
sudo gedit /etc/pm/sleep.d/wakenet.sh
Insert the following lines: #!/bin/bash case "$1" in thaw|resume) nmcli nm sleep false ;; *) ;; esac exit $? [/CODE]
And then you save the gedit file.
When I do that I get this error:
CODE: Gtk-WARNING **: Calling Inhibit failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
(gedit:24243): Gtk-WARNING **: Calling Inhibit failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
[/CODE]
Anyone know how to get out of this problem? I have to always unplug my router its annoying because I need Ubuntu for school.
Thanks in advance
I have a HP Pavilion g6.
Pew
Gedit gives me similar errors as well. I don't know why, but the program still works well for me, and it has worked for you as well.
But I understand if the errors concern you; you can try using the nano text editor instead of gedit. It is command line-based. Just replace gedit with nano when you are entering a command. To save, use Ctrl+O, and to exit, Ctrl+X. If you made changes to a file without saving, using Ctrl+X will give a prompt at which you can decide to save your changes, go back, or discard your changes.
Also, be sure to make your discussion title more relevant to the issue you're experiencing so as to not mislead anyone willing to provide you with solutions, out of respect to the forum, its users, and its visitors. Further, a more specific title will more likely attract those who have experienced your issue to help you or even those who have not experienced it but know that they can help.
user311982
  • 1,295
