uugana@Hunnu:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up icedtea-netx:i386 (1.5.1-1ubuntu1) ...
update-alternatives: warning: forcing reinstallation of alternative /usr/lib/jvm/java-6-openjdk-i386/jre/bin/itweb-settings because link group itweb-settings is broken
update-alternatives: warning: not replacing /usr/share/man/man1/itweb-settings.1.gz with a link
update-alternatives: error: alternative path /usr/lib/jvm/java-7-openjdk-i386/jre/bin/itweb-settings doesn't exist
dpkg: error processing package icedtea-netx:i386 (--configure):
 subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of icedtea-7-plugin:i386:
 icedtea-7-plugin:i386 depends on icedtea-netx (= 1.5.1-1ubuntu1); however:
  Package icedtea-netx:i386 is not configured yet.
dpkg: error processing package icedtea-7-plugin:i386 (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 icedtea-netx:i386
Mitch
  • 109,787
Try sudo apt-get upgrade --fix-broken --fix-missing
Thomas Ward
  • 78,878
rhubarbdog
  • 422
