10
I have upgraded from Ubuntu Gnome 14.04 to 14.10 yesterday using standard Software Updater GUI. The upgrade went smooth, however once upgrade was done I've noticed significant desktop performance degradation only when certain applications are running at the time. Basic desktop operations like switching between workspaces is accompanied by visible lag and stuttering, which is extremely annoying and disruptive in daily workflow.
I've recorded a screencast demonstrating this problem - I've used standard Image Viewer application (ver. 3.12.2) and Google Chrome as example apps causing this issue - which is not to say that these are ONLY applications causing it.
The screencast video: https://www.youtube.com/watch?v=0LhKhdgKHiQ
I've googled around this issue and tried several workarounds related to GPU's hw acceleration, yet none of these attempts fixed the problem.
Any help or pointers would be much appreciated.
EDIT:
As suggested in the comment below, I've executed glxinfo to gather additional graphics/acceleration data, however I don't have a clue how to read this: http://pastebin.com/JRuTgQSa
Additionally, I've filed a bug report in Launchpad: https://bugs.launchpad.net/ubuntu-gnome/+bug/1385764
If you have Integrated Intel graphics, you could try
sudo apt-get install xserver-xorg-video-intel
then rebooting. This worked for me on a Dell XPS laptop - everything became smooth again. Source: https://bugs.launchpad.net/ubuntu-gnome/+bug/1385764
If you subsequently have problems with
optirun glxgears
giving "Can't open secondary"...
Try,
 sudo apt-get install nvidia-331-updates
then
 gksudo gedit /etc/bumblebee/bumblebee.conf
Under the section [bumblebeed] change the Driver: Driver=nvidia
Under [driver-nvidia] change references in this section from nvidia-current to nvidia-331-updates. That's in the KernelDriver, XorgModulePath and LibraryPath.
Then reboot, and try
optirun glxgears
Source: http://mylinuxexplore.blogspot.co.uk/2014/03/solved-nvidia-cant-access-secondary-gpu.html
Chrisky
  • 211
I fixed a similar issue by switching my gpu acceleration method from 'sna' to 'uxa'. See https://wiki.archlinux.org/index.php/Intel_graphics#SNA_issues
If you are experience issues with SNA, try using UXA instead, which can be done by creating an X configuration file containing the following:
/etc/X11/xorg.conf.d/20-intel.conf
Section "Device" Identifier "Intel Graphics" Driver "intel" Option "AccelMethod" "uxa" EndSection
