As I have searched for days and days online and couldn't find any solutions I decided to ask personally.
I have MSi CX620MX laptop and I just upgraded from Ubuntu 14.04 to 14.10
This is a laptop we got from a friend, it used to have finnish windows on it and sice we don't comprehend finnish that well we decided to just clean the laptop and intall ubuntu instead. When we got it it was still able to go online via wifi but it had a problem with the keyboard so we had to remove the built in keyoard with the finnish windows.
So ... now I have a laptop with Ubuntu 14.10 and no functioning fn+F8 button to turn on the wifi.
The computer claims the wireless is disabled by hardware switch. I also can't use bluetooth, perhaps these two problems are connected?
So I tried to follow some guide on how to install a driver but when running "lspci -nn -d 14e4:" I get nothing....
No idea what to do .. please help me to turn on wireless :(
Maybe in 14.04 you had enabled a hardware driver and no longer needed in 14.10? Go to:
System Settings -> Software&Updates -> additional drives and "Do not use this device"
Worked for me )
Tomvo
  • 661
Boot into the BIOS and you should find a setting that allows you to enable/disable the hardware switch, a check box for the wireless device you want controlled by the switch. This could be a physical switch such as a slide switch or a certain key combination such as Fn+F4. On my Dell I just cleared both boxes "Bluetooth and WiFi" and saved. Now it makes no difference what my "switch" is set to my radios are always on unless I turn them off in Ubuntu.
