I want to install a bunch of packages, but I don't want to install the documentation of them. How can I do this?
muru
  • 207,228
Robert
  • 181
Exclude documentation from .deb installation (DPKG)
  • Onetime option: --path-exclude could be used to filter out unwanted files when installing a package:
    dpkg -i --path-exclude=/usr/share/doc/* ...
  • Permanent solution: Create a file /etc/dpkg/dpkg.cfg.d/01_nodoc which specifies the desired filters. Example:
    path-exclude /usr/share/doc/*
    # we need to keep copyright files for legal reasons
    path-include /usr/share/doc/*/copyright
    path-exclude /usr/share/man/*
    path-exclude /usr/share/groff/*
    path-exclude /usr/share/info/*
    # lintian stuff is small, but really unnecessary
    path-exclude /usr/share/lintian/*
    path-exclude /usr/share/linda/*
Skip recommended dependencies (APT)
Then change /etc/apt/apt.conf.d/99synaptics or create new file containing:
APT::Install-Recommends "false";
By the way, this is the permanent option of muru's answer for this question.
References:
user.dz
  • 49,176
Usually, the doc packages are recommended by the main package, but aren't hard dependencies. If they were hard dependencies (for example, texlive-full), I don't think there's a safe or simple way. For recommended packages, the answer is simple:
sudo apt-get install --no-install-recommends <package-name>
muru
  • 207,228
