11
When I am using xdg-open to open a link in Chromium, it just results in a new Chromium window with only the new tab page, with nothing else.
For example, xdg-open 'https://askubuntu.com' will just open a new Chromium window and won't open up AskUbuntu.
It just seems that the URL isn't being passed to Chromium, as invoking Chromium directly does work and opens the desired page: chromium-browser 'https://askubuntu.com' works.
Obviously, Chromium is the default browser.
Where could the problem be, and how can I fix that? It is especially annoying when some programs use xdg-open to open a link and you can't go to the page you want, or even see what was opened.
Léo Lam
  • 1,012
  • 27
The issue is indeed that xdg-open does not pass the requested URL to Chromium, so instead of running chromium-browser url-here, it is executing chromium-browser which just opens a new window.
After searching on the Internet, I found out that xdg-open uses some "config" files located in /usr/share/applications.
/usr/share/applications/chromium-browser.desktop seemed to be correct, as it is configured to pass the URL to Chromium correctly:
$ grep Exec /usr/share/applications/chromium-browser.desktop
Exec=chromium-browser %U
So what was wrong? It turns out that there's another location which xdg-open uses and that has priority over /usr/share/applications.
$ grep Exec ~/.local/share/applications/chromium-browser.desktop
Exec=/usr/lib/chromium-browser/chromium-browser --use-system-title-bar --ppapi-flash-path=/usr/lib/pepflashplugin-installer/libpepflashplayer.so --ppapi-flash-version=14.0.0.125
I have no idea as to why there's another chromium-browser.desktop, but note that this Exec line does not pass the URL; it is missing the %U. So I simply appended %U to this line. This instantly fixed all issues with xdg-open and Chromium.
Léo Lam
  • 1,012
  • 27
