lynda@lynda-Aspire-3680:~$ lspci -vnn | grep 14e4
0a:03.0 Network controller [0280]: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller [14e4:4318] (rev 02)
lynda@lynda-Aspire-3680:~$ sudo apt-get install b43-fwcutter
[sudo] password for lynda:
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
The process seems to be hanging after 'install completed':
Loading new bcmwl-6.30.223.141+bdcom DKMS files... Building only for 3.13.0-37-generic Building for architecture i686 Building initial module for 3.13.0-37-generic Done.
wl: Running module version sanity check. - Original module - No original module exists within this kernel - Installation - Installing to /lib/modules/3.13.0-37-generic/updates/dkms/
depmod....
DKMS: install completed.
In another Terminal I get:
nmcli nm RUNNING STATE WIFI-HARDWARE WIFI WWAN-HARDWARE WWAN
running connected enabled enabled enabled disabled
Cannot afford to spend any more time on this. 14.04 has been a disappointment - have had more problems on recent installs than I ever had on 12.04. Will now downgrade.
DeanH
Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable) E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
This usually means you have another window open somewhere that is running updates or installing software. You can only run one dpkg process at a time. Ensure that other operations are finished and you do not have another package manager like synaptic running when you run an apt-get command
Duck
  • 336
