The Pip program is included by default with Python 3.4, and can also be installed on older versions. The aim is to provide a standard method of installing additional Python modules, which are available from the Python Package Index
For example, to add the PyOpenGL module, you can now just do this
pip install pyopengl
And Pip will take care of the rest. I can see that this would be very useful on systems other than Ubuntu-based ones. But I could just as easily do this
sudo apt-get install pyopengl
and the end result is the same.
So my question is, is there any reason to use Pip on Ubuntu at all, can I just stick with using Synaptic, or should I always be using Pip for Python packages (where they're available, not all are), or does it really not matter?
Carl H
  • 6,316
  • 28
  • 42
