i have a problem trying to safely remove an external portable drive in Ubuntu 14.04 because when i tried to safely remove the drive it closes for a while but then just keeps coming back(mounts itself again and opens a window).
there was that one time only that when i safely remove the drive it just completely removed the drive where the drive stopped spinning and the LED indicator turned off just like when i safely remove it in Windows. i did not changed any settings i just turned on my computer, copied a file, then safely removed the drive.
what is the problem with this? is there a solution? i just wan't to safely remove my drive by making sure it stops spinning and the LED indicator is off. i know its possible because it happened once.
Additional info that could be useful Drive is a Seagate Backup Plus Slim 1TB Ubuntu 14.04 is a fresh installation.
if you need additional info just ask.
