Hello i'm trying to install uTorrent to my Ubuntu 11.04
I'm downloading it from here . But it's a .tar.gz file. I'm untaring it with
tar -xzvf utorrent-server-3.0-25053.tar.gz
command. But there isn't any make file, etc. I can understood, how can i install it ?
Jjed
  • 14,064
Eray
  • 1,820
It's a tar file with all the files already in it (I had a peek inside the tar file).
The command to start it looks like utserver inside ./utorrent-server-v3_0
utserver: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.15, not stripped
Also have a look at ./utorrent-server-v3_0/docs/ for the file uTorrent_Server.html.
If you are looking for the client you need wine to run it. I would advice looking for another client. Both deluge and transmission are perfect for downloading torrents.
Rinzwind
  • 309,379
Utorrent is providing 32bit executable directly. So if you have 32bit Ubuntu installation then follow these steps.
  1. Go to extracted folder
  2. run utserver
    ./utserver
  3. Now go to browser and type http://localhost:8080
You might need to configure few things. However, as the binary is 32bit, I could not run this lib on my 64bit OS setup.
Follow this official discussion page for more detailed installation steps.
Amey Jah
  • 2,735
If you like utorrent in Windows and want the same experience in Ubuntu you better give up utorrent here (at least at its present stage). I also tried utorrent in Wine and it was unstable and heavy. The most utorrent-like experience in Ubuntu is through qBittorrent and Flush. See HERE.
