I want to use the latest yEd graph editor on my machine with Ubuntu 14.04 running on it as the only OS. I downloaded yEd installer script for 64-bit Linux. Also:
$ java -version
java version "1.8.0_25"
Java(TM) SE Runtime Environment (build 1.8.0_25-b17)
Java HotSpot(TM) 64-Bit Server VM (build 25.25-b02, mixed mode)
yEd installs with no problem, however when I launch the application it only shows me this window.
And after clicking on e.g. "New Document" the window closes and nothing else happens. This is while the application shows to be running. The point is that no errors or warnings are shown whatsoever. I am not sure what I should do at this point. Any help is appreciated.
In case you would like to look at the log, it can be found here.
Iman
