39
There are three machines in this scenario:
  • Desktop A : user@1.23.x.x
  • Laptop A : user@1.23.y.y
  • Machine B : user@192.168.z.z
All the machines have Ubuntu 11.04 (Desktop A is a 64bit one) and have both openssh-server and openssh-client.
Now when I try to connect Desktop A to Laptop A or vice-versa by ssh user@1.23.y.y I get an error as
port 22: No route to host
in both the cases.
I own both the machines, now if I try same commands from my friend's machine, i.e. via Desktop B, I can access both my Laptop and Desktop. But if I try to access Desktop B from my Laptop or by Desktop I get
port 22: Connection timed out
I even tried changing ssh port no. in ssh_config file but no success.
Note: that 'Laptop A' uses WiFi connection while 'Machine A' uses Ethernet Connection and 'Machine B' is on an entirely different network.
@Lekensteyn Here it is ->
Laptop A && Desktop A -> Router/Nano_Rcvr provided to me by ISP. So to one Router two Machines are connected and can be accessed at the same time. here is my ifconfig output for both the machines :- Laptop
wlan0
      Link encap:Ethernet  HWaddr X:X:X:X:00:bc
      inet addr:1.23.73.111  Bcast:1.23.95.255  Mask:255.255.224.0
      inet6 addr: fe80::219:e3ff:fe04:bc/64 Scope:Link
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:108409 errors:0 dropped:0 overruns:0 frame:0
      TX packets:82523 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:44974080 (44.9 MB)  TX bytes:22973031 (22.9 MB)
Desktop
eth0
      Link encap:Ethernet  HWaddr X:X:X:X:c5:78
      inet addr:1.23.68.209  Bcast:1.23.95.255  Mask:255.255.224.0
      inet6 addr: fe80::227:eff:fe04:c578/64 Scope:Link
      RX packets:10380 errors:0 dropped:0 overruns:0 frame:0
      TX packets:4509 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:1790366 (1.7 MB)  TX bytes:852877 (852.8 KB)
      Interrupt:43 Base address:0x2000
Output of ip route show
      1.23.64.0/19 dev wlan0  proto kernel  scope link  src 1.23.73.111  metric 2
      169.254.0.0/16 dev wlan0  scope link  metric 1000
Output of traceroute -n 1.23.73.111
       traceroute to 1.23.73.111 (1.23.73.111), 30 hops max, 60 byte packets
       1  1.23.68.209  3008.787 ms !H  3008.786 ms !H  3008.784 ms !H
8 Answers8
23
The routes look fine. I'll assume that those IP addresses are private ones (LAN) and not public accessible.
Since you're connected in different ways to the network (wifi / wired), it's very likely that your router has separated wired / wireless networks. Try connecting both of them on a wired (or wireless) connection. Another possibility is that a firewall on the Ubuntu machines is blocking connections.
Otherwise, configure your router to use the same network (subnet) for wireless and wired connections. Also make sure that the router does not block client-to-client communication.
Your router is possibly dropping all unsolicited packets, that's why your friend gets a "connection timed out" message on your public IP address. Configure NAT port forwarding so that the public IP address + port combination forwards to your LAN address.
Example network:
YOUR NETWORK (A)
    Router A (public address: 198.51.100.1)
    Desktop A - 10.0.0.2
    Laptop  A - 10.0.0.3
YOUR FRIENDS NETWORK (B)
    Router B (public address: 203.0.113.1)
    Machine B - 192.168.0.2
On Router A, setup NAT forwarding:
To make your desktop accessible:
  forward the public port 22 to 10.0.0.2
To make your laptop accessible:
  forward the public port 2222 to 10.0.0.3
If you've a firewall (ufw, iptables, ...) on the machines set, allow incoming traffic to port 22 (Desktop A) and port 2222 (Laptop A).
The desktop can now be accessed using SSH with:
ssh user@198.51.100.1 -p 22
The laptop can now be accessed using SSH with:
ssh user@198.51.100.1 -p 2222
If you want to access your friends machine, apply these instructions to his machine + router.
Lekensteyn
  • 178,446
i had a similar problem. One machine on wire one wireless. I found a tickbox in my router besides "seperate ips for lan and wlan" and ticked it off. Now i can login to the wireles computer. Before that i got the error message "No route to host".
smev9
  • 41
I would weirdly get this error even after successfully running SSH between my PC and raspberry Pi. What fixes it for me is turning wifi off and on (both client and host), restarting your terminal and using new ip addresses.
Josh
  • 131
In my case there was a Docker network on the same CIDR as my VPN.
I used the following command to figure out which network, and then I removed it:
docker inspect $(docker network ls -q) | jq '.[] | {name: .Name, cidr: .IPAM.Config[0].Subnet}'
After that it worked fine.
Check the ssh check box while installing RHEL. I did not check it and causing the same issue. Please check that parameter
I got the same issue myself now on a vps, and its completely weird, never seen anything like it.
I am an experienced server admin and this sort of error is normally cut and dry.
No route to host means the server doesnt know how to route the packet (routing table, however I have never seen it only occur on one protocol and not another).
In my case.
No NAT Internet connection. No IPTABLES Ping works I can connect to ip's either side of the broken ip. The broken ip says "no route to host" on any tcp port.
This suggests either something in the middle is returning the error code or a bug in the OS with the routing table.
Note the error is instant, not a delay meaning the rejection is local. But thats all I can diagnose.
root@vps1 network # telnet 83.149.xx.xx 23
Trying 83.149.xx.xx...
telnet: Unable to connect to remote host: No route to host
root@vps1 network # telnet 83.149.xx.xx 80
root@vps1 network # ping 83.149.xx.xx
PING 83.149.xx.xx (83.149.xx.xx) 56(84) bytes of data.
64 bytes from 83.149.xx.xx: icmp_seq=1 ttl=56 time=8.89 ms
64 bytes from 83.149.xx.xx: icmp_seq=2 ttl=56 time=7.93 ms
I was facing the issue with Docker network as well and M.Vanderlee's answer helped me identify which of my networks was causing the issue. Unfortunately it was my Docker default bridge network and I'm not supposed to delete it. (Trying to delete your default network throw's the error Error response from daemon: bridge is a pre-defined network and cannot be removed.
So, in order to resolve the issue, I had to change the CIDR of the default bridge network. Here's how to do it - Edit the /etc/docker/daemon.json (creating a file with this name if it doesn't exist is OK) file and change the default-address-pools value there to anything other than what you would want to connect to outside the world of Docker, and restart Docker daemon. Following is an example of the file contents:
 "default-address-pools":
 {"base":"10.2.0.0/16","size":24}
-4
If you have changed/replaced your system hard drive incase then try removing the hostkey from .ssh/known_hosts file then try connecting again.
