I'm trying to make Resynthesizer plug-in work in Gimp 2.8.10 under Ubuntu 14.04 TLS but I get this error:
Traceback (most recent call last):
  File "/usr/lib/gimp/2.0/python/gimpfu.py", line 699, in response
    dialog.res = run_script(params)
  File "/usr/lib/gimp/2.0/python/gimpfu.py", line 361, in run_script
    return apply(function, params)
  File "/home/olivier/.gimp-2.8/plug-ins/plugin-heal-selection.py", line 148, in heal_selection
    pdb.plug_in_resynthesizer(timg, tdrawable, 0,0, useBorder, work_drawable.ID, -1, -1, 0.0, 0.117, 16, 500)
error: procedure not found
I downloaded the plugin here: http://registry.gimp.org/node/27986, extracted all in /home/olivier/.gimp-2.8/plug-ins/
Then make all files in this folder read, write, execute.
But I get this error. I have no more ideas.
A same question was launched in November last year and was closed because it was a bug report issue. Is it still the same one year later?
αғsнιη
  • 36,350
Kamadji
  • 31
Simply put, this is v1.0, while v2.0 is already available (not as a build though).
You can fetch source code from https://github.com/bootchk/resynthesizer and build it.
I had the same error as you. After removing the current non working plugin files, look up "gimp-plugin-registry" in the ubuntu software center. After I installed this the heal selection filter was available and worked.
Will
  • 121
