A person gave me a computer and it has this program installed but he has passwords pretty much on everything so I can't download anything, is there away to get through that.. Please help!!! Thanks a bunch
If the computer is yours you shouldn't have to be concerned with passwords and the problems of the computer. You might best just download and burn an Ubuntu DVD and install fresh. Starting fresh will ensure that you have files complete and can download whatever you want in a more personal manner. Since you'e just getting the computer, what would you be loosing.
As far as passwords, having physical access to the computer, it would be easy to setup your own passwords. Use the same install disk that I just suggested, login the try option, mount the drive and remove the root password from the boot partition. Then you'd be able to log in as root and setup new passwords.
Once booting into the try ubuntu you can mount the disk from the commandline with:
Find the partition with the Ubuntu installtion:
$ cat /proc/partitions
Mount that partition:
$ sudo mount /dev/[desired partition] /mnt
The desired partition is the one with the installation
$ sudo nano /mnt/etc/passwd
Change from:
root:x:0:0:root:/root:/bin/bash
Change to (remove the x from the password field):
root::0:0:root:/root:/bin/bash
Now you can exit out of the try ubuntu and boot to the OS. You can log in as root and remove or change any of the passwords to whatever you want them to be.
- 25,444
A simple way that doesn't involve enabling the root account (and is therefore more secure), would be to reset the user password from recovery mode with
passwd [USERNAME]
where [USERNAME] is the name of the user you're usually working as.
Alternatively a live system can be used, which is more tedious as it involves mounting and setting up a chroot environment.
- 36,890
- 56
- 97
- 151
