I'm using Ubuntu 13.04. When I try sudo apt-get update --fix-missing, I get a bunch of 404/Not Found and 403/Forbidden errors and it's preventing apt-get from working most of the time.
I can paste the full output if it's helpful, but here are just a few lines that might indicate the issue:
Err http://us.archive.ubuntu.com quantal-backports/main i386 Packages
  404  Not Found [IP: 91.189.91.23 80]
Err http://us.archive.ubuntu.com quantal-backports/restricted i386 Packages
Err http://us.archive.ubuntu.com quantal-backports/universe i386 Packages
Err http://us.archive.ubuntu.com quantal-backports/multiverse i386 Packages
W: Failed to fetch http://apt.basho.com/dists/quantal/main/binary-amd64/Packages  403  Forbidden
W: Failed to fetch http://apt.basho.com/dists/quantal/main/binary-i386/Packages  403  Forbidden
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/quantal/main/source/Sources  404  Not Found [IP: 91.189.91.23 80]
I know that Quantal reached end-of-life in May 2014.
I don't really care about using Quantal stuff -- and in fact I'm not quite sure why these Quantal packages are here given that I'm using 13.04.
I don't want to upgrade to 14.
As a single isolated example, I'd like to install the default Java development kit:
user@device:~/ $ sudo apt-get install default-jdk
but this results in the above package errors, and more package errors if I try apt-get update --fix-missing, as noted.
How should I go about using apt-get to install the JDK without upgrading to a different version of Ubuntu?
Braiam
  • 69,112
Just edit your sources.list to point to the old-releases servers, as described in directions for EOL upgrades (https://help.ubuntu.com/community/EOLUpgrades), and proceed to install as you see fit.
A word of caution: you won't get any updates, even security related. Even simple updates. So, even though this is the answer to your question, it is still recommended that you upgrade to an LTS release.
Good luck.
user7134
  • 459
