12
I recently did a fresh install of Ubuntu 14.04. When I SSH, there is no MOTD (and yes, I have the appropriate command set in sshd_config).
I read a bunch of tutorials about setting up MOTD, but I realized that while I have /etc/update-motd.d, there is not /etc/motd file nor a /var/run/motd file.
How can I set these up so that I can get a MOTD via SSH?
alxlvt
  • 253
On a base install of Ubuntu 14.04.2 LTS, simply drop the message you want in:
/etc/motd
By default, the MOTD will appear at the end of the other dynamic MOTD content. For example, here's the output from a Vagrant ubuntu/trusty64 (v20150506.0.0) box with a /etc/motd file added:
$ vagrant ssh
Welcome to Ubuntu 14.04.2 LTS (GNU/Linux 3.13.0-52-generic x86_64)
 * Documentation:  https://help.ubuntu.com/
  System information as of Thu May 14 20:06:56 UTC 2015
  System load:  0.39              Processes:           78
  Usage of /:   2.8% of 39.34GB   Users logged in:     0
  Memory usage: 24%               IP address for eth0: 10.0.2.15
  Swap usage:   0%
  Graph this data and manage this system at:
    https://landscape.canonical.com/
  Get cloud support with Ubuntu Advantage Cloud Guest:
    http://www.ubuntu.com/business/services/cloud
0 packages can be updated.
0 updates are security updates.
Howdy! This message is from /etc/motd
Last login: Thu May 14 20:06:56 2015 from 10.0.2.2
vagrant@vagrant-ubuntu-trusty-64:~$
That's all there is to it if you're working on a system with the default settings.
Some other troubleshooting notes:
  • Using "/etc/motd" is a change from earlier versions. Recommendations for 12.02 were to use "/etc/motd.tail". That doesn't work in 14.04.2.
  • Other recommendations I've seen include changing some values in "/etc/ssh/sshd_config". In case those have been altered, here's the defaults that work:
    UsePAM yes
    PrintMotd no
  • Likewise, here are the defaults for the /etc/pam.d/login I've seen referenced:
    session    optional   pam_motd.so  motd=/run/motd.dynamic noupdate
That's everything I've seen referenced for troubleshooting.
Try to add:
 UsePAM yes
in your /etc/ssh/sshd_config as suggested in this bug and in Can't configure MOTD properly in Ubuntu 10.04 Server (update-motd command not found)
With UsePAM enabled, PAM will automatically update the MOTD and print it for you when you log in. You have to disable PrintMOTD or SSH will print it as well, so you'll see it twice, which is annoying.
I'm not sure about this, but in case you get motd twice, you should set PrintMOTD to no.
Lety
  • 6,089
  • 32
  • 38
Add the following line to /etc/pam.d/sshd :
hg8
  • 13,582
In my case, it was because one of the scripts in /etc/update-motd.d failed to run (giving a non-zero exit code). Fixing it made MOTD start appearing again.
If you're unsure which one it is, just append a line exit 0 to all scripts in that directory.
I noticed this on my machines running Ubuntu Disco and Debian Buster, but I am confident that it's applicable on Ubuntu Trusty (and even Precise).
iBug
  • 1,859
