I have a login problem with a game (league of legends - the login server did not respond).I found somewhere that I need to install lib32-gnutls to fix this problem, but I don't know how to do this.
I downloaded the files from here: https://www.archlinux.org/packages/multilib/x86_64/lib32-gnutls/
Inside the folder lib32-gnutls are these files:
libgnutls-openssl.so         libgnutls.so.28            libgnutlsxx.so.28.1.0
libgnutls-openssl.so.27      libgnutls.so.28.41.0  pkgconfig
libgnutls-openssl.so.27.0.2  libgnutlsxx.so
libgnutls.so                 libgnutlsxx.so.28
I tried to install them through terminal with:
sudo apt-get install 'the name of the file'
but I get:
Reading package lists... Done
Building dependency tree
W: Duplicate sources.list entry http://dl.google.com/linux/chrome/deb/ stable/main i386 Packages (/var/lib/apt/lists/dl.google.com_linux_chrome_deb_dists_stable_main_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
E: Unable to locate package libgnutls.so.28
E: Couldn't find any package by regex 'libgnutls.so.28'
I have ran the command apt-get update.
So what should I do next?
I had the same problem and solved with this: basically you have to open playonlinux, choose right click League of legends -> Registry editor and then delete:
HKEY_CURRENT_USER\Software\Wine\DllOverrides
kenorb
  • 10,944
Leggy7
  • 136
