Can anyone help me troubleshoot this? I tried looking online but for some reason not a lot is coming up, as if it's a big secret or something.
Every time I connect to it I see "/dev/sdc should be checked for errors" and below that (not sure if this is related) it says ***** System restart required *****
I did not set this server up but what I do know is /dev/sdc is an iSCSI connection to a RAID volume on a Promise VessRAID 1840i.
Are there ways to test the volume w/out unmounting the filesystem or effecting user's access to the data on it? If so please explain what needs to be done.
Thanks!
00fruX
  • 1,271
  • 17
  • 32
You'll need to unmount the drive to check the file system for errors. You can't do it while the filesystem is live.
  • Ensure FSCKFIX=yes is present in /etc/default/rcS (it's no by default).
  • Run touch /forcefsck, and reboot the system.
  • Revert your changes to rcS once fsck is complete.
Boinst
  • 131
