I'm running bully on Ubuntu 14.04 LTS. I got this output:
educ@educ-TOSHIBA-NB500:~$ sudo apt-get install libnl-3-dev libnl-genl-3-dev libssl-dev
[sudo] password for educ:
Reading package lists... Done
Building dependency tree
libnl-3-dev is already the newest version.
libnl-genl-3-dev is already the newest version.
libssl-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
educ@educ-TOSHIBA-NB500:~$ sudo bully mon1 -b XX:XX:XX:XX:XX:XX -c 8 -v 3 -C -F -l61
Unable to get hardware MAC address for 'mon1'
Please specify --source for the interface
educ@educ-TOSHIBA-NB500:~$ sudo airmon-ng
Interface    Chipset        Driver
wlan3        Ralink RT2870/3070    rt2800usb - [phy1]
wlan0        Unknown     rtl8192ce - [phy0]
educ@educ-TOSHIBA-NB500:~$ sudo airmon-ng start wlan3
Found 3 processes that could cause trouble.
If airodump-ng, aireplay-ng or airtun-ng stops working after
a short period of time, you may want to kill (some of) them!
-e
PID    Name
674    NetworkManager
842    wpa_supplicant
2213    dhclient
Process with PID 2213 (dhclient) is running on interface wlan0
                (monitor mode enabled on mon0)
educ@educ-TOSHIBA-NB500:~$ sudo bully mon0 -b  XX:XX:XX:XX:XX:XX  -c 8 -v 3 -C -F -l61
[!] Bully v1.0-22 - WPS vulnerability assessment utility
[+] Switching interface 'mon0' to channel '8'
[!] ioctl(SIOCSIWFREQ) on 'mon0' failed with '-1'
[X] Unable to set channel on 'mon0', exiting
When I run sudo airodump-ng mon0, it works fine.
What does this error message mean?
I didn't have that problem with bully on Ubuntu 12.10 LTS until i upgrade it to 14.04 What can i do to solve that problem?
any help would be appreciated
Educ
  • 109
Do this:
sudo gedit /etc/default/ifplugd
Then put this line in the file:
HOTPLUG_INTERFACES=""
Save it and you are good to go!
That's it, problem was: your device is busy. Found in http://blog.flowl.info/2014/wlan-problem-device-resource-busy-solution/
Vini
