I have Ubuntu 14.04 64-bit installed. I installed wine from PPA 1.7.28 64 bit. How can I have a second instance of Wine in 32-bit? How can I launch some programs only in 32-bit?
I won't delete my 64-bit version of wine, because some games run better on with the 64-bit version. But I need a 32-bit version for Photoshop.
MadMike
  • 4,275
  • 29
  • 50
I solved it by following these steps:
  1. My 64-bit wine configuration is located under the directory /home/username/.wine/
  2. Add a 32-bit wine configuration:
    WINEPREFIX='/home/username/.wine32' WINEARCH='win32' wine 'wineboot'
  3. Add a alias in ~/.bashrc:
    alias wine32="WINEPREFIX='/home/username/.wine32'"
Now you can use both 32-bit and 64-bit version of wine. In order to use the 64-bit version, just do as you usually did:
wine Program.exe
But in order to use 32-bit version it's a bit different. Call the alias like this:
wine32 wine Program.exe
I Hope this will be useful for other people.
MadMike
  • 4,275
  • 29
  • 50
If you want to use different versions of wine, I recommend PlayOnLinux. With this you can, not only install 32 bit and 64 bit wine, but also different versions of wine.
Install it with sudo apt-get install playonlinux or use Ubuntu Software Center.
To Do
  • 15,833
