-1
Ok, so updating my question, maybe this'll help...
I'm trying to install Marathon, on this page it says to unpack the tar.bz2 file and run (I'm assuming this means in Terminal)
./configure && make && make install
but it returns as,
bash: ./configure: No such file or directory
Not sure what to do here
  1. Open a terminal and navigate to the folder where you saved the file:
    cd /home/$USER/<my_marathon_download_folder>
  2. Extract the archive with this command:
    tar xf AlephOne-20140104.tar.bz
  3. Change the folder again:
    cd AlephOne-20140104
  4. Now you can start with ./configure:
    ./configure
    This command is likely to fail with an error because you'll probably have to install some libraries. But since I do not know your system, I can not tell you which libraries are.
    In my case I need, for example, the development library for SDL:
    checking for SDL - version >= 1.2.0... no
    These can be installed with this command:
    sudo apt-get install libsdl1.2-dev
A.B.
  • 92,125
