I was able to connect only once and use internet. That time, lsusb displayed:
Bus 002 Device 005: ID 12d1:1506 Huawei Technologies Co., Ltd. E398 LTE/UMTS/GSM Modem/Networkcard
But after I disconnected the data card and tried to connect, its not connecting to the internet. lsusb now displays:
Bus 002 Device 007: ID 12d1:1446 Huawei Technologies Co., Ltd. E1552/E1800/E173 (HSPA modem)
I am not able to understand what should I do to again able to connect to internet. Please guide me to make this work.
Thomas Ward
  • 78,878
To use Datacard on Ubuntu OS, find the step below. Read them carefully before you take the step and do not miss the step mentioned herein. To use on Ubuntu OS, find the step below. Read them carefully before you take the step and do not miss the step mentioned herein.
1.You try to connect datacard stick and boot up Ubuntu / system.
2.You may choose network connections and click on the 'New Mobile Broadband Connection'
3.Select 'continue' in the dialog box and select "India" as country & then click continue.
4.It will show the list of service providers, select Tata Photon+ (2G).
5.Now, under billing dialog, select the plan as Tata Photon+ (2G) just click 'confirm' and save your settings.
6.After these steps, you will get Network Connections, you will find "Tata Photon+ (2G)" option and click on it. In case if it does not connect to internet then you can just unplug and then plug your 3G stick.
7.That's it the step, now you can enjoy by using Tata photon 3G stick with your Ubuntu OS.
Hope this helps!
BDRSuite
  • 3,196
  • 13
