Here is the full rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
touch /home/jack/test.txt
bash /home/jack/Scripts/select_wallpaper.sh
exit 0
When executing the script manually no problem occures and everything works fine. I have tried to put the test command touch into the rc.local but nothing happens!? I have checked the sysv-rc-conf and it is enabled! What am I missing??
Here is the content of my /etc/init.d/rc.local:
 #! /bin/sh
### BEGIN INIT INFO
# Provides:          rc.local
# Required-Start:    $all
# Required-Stop:
# Default-Start:     2 3 4 5
# Default-Stop:
# Short-Description: Run /etc/rc.local if it exist
### END INIT INFO
PATH=/sbin:/usr/sbin:/bin:/usr/bin
. /lib/init/vars.sh
. /lib/lsb/init-functions
do_start() {
    if [ -x /etc/rc.local ]; then
        [ "$VERBOSE" != no ] && log_begin_msg "Running local boot scripts (/etc/rc.local)"
    /etc/rc.local
    ES=$?
    [ "$VERBOSE" != no ] && log_end_msg $ES
    return $ES
fi
echo $1 > /home/jack/test.txt
case "$1" in
start)
do_start
restart|reload|force-reload)
    echo "Error: argument '$1' not supported" >&2
    exit 3
stop)
    echo "Usage: $0 start|stop" >&2
    exit 3
esac
I inserted the line echo $1 > /home/dan/test.txt myself but nothing is written there!? When I execute it like sudo /etc/init.d/rc.local start everything works fine just not when booting the system!?
wasp256
  • 837
I put the script in the Startup Applications and it works now fine
wasp256
  • 837
