We have the following MAAS setup-
One node is setup as the server with both MAAS cluster and region controllers running on it. We added 2 nodes which are in a private virtual LAN with the server node. We brought the nodes into 'Ready' state and installed juju on the server. Now when we try to run juju bootstrap, it says Attempting to connect to 10.10.10.104 and fails after 10min with the connection refused error. 10.10.10.104 is one of our node in the private vLAN and that which was already in MAAS.
My suspicion is - the node is in 'Ready' state and hence no OS is installed yet on it. juju is attempting to connecting to it. It should obviously be unable to connect, as MAAS collects all info required from the nodes during PXE boot and shuts down the machines.
juju wants to install OS on the nodes but the machines are not up.
PS: Our power on type is IPMI
EDIT: On running juju bootstrap --debug, we see a slew of these messages
2014-10-12 02:50:58 DEBUG juju.utils.ssh ssh_openssh.go:122 running: ssh -o "StrictHostKeyChecking no" -o "PasswordAuthentication no" -i /root/.juju/ssh/juju_id_r sa -i /root/.ssh/id_rsa ubuntu@slot13.maas /bin/bash
And after 10mins, it now fails with
waited for 10m0s without being able to connect: /var/lib/juju/nonce.txt does not exist
