When I run ddclient (DynamicDns Updator) without sudo, I get
WARNING:  file /etc/ddclient.conf: Cannot open file '/etc/ddclient.conf'. (Permission denied)
stat() on closed filehandle FD at /usr/sbin/ddclient line 934.
Use of uninitialized value $mode in bitwise and (&) at /usr/sbin/ddclient line 935.
readline() on closed filehandle FD at /usr/sbin/ddclient line 947.
WARNING:  file /var/cache/ddclient/ddclient.cache: Cannot open file '/var/cache/ddclient/ddclient.cache'. (Permission denied)
However it works fine with sudo.
Do I need to chmod some files? If yes, please explain how.
N.N.
  • 18,589
Amith KK
  • 13,547
In a default setup root runs ddclient as a daemon using setting from /etc/ddclient.conf. Runtime options are defined in /etc/default/ddclient.
We are able to start ddclient with another configuration file by using the option:
ddclient -file <path>
For further options see also the ddclient wiki.
It is not recommended to change permissions for the default files as this may lead to security issues.
Takkat
  • 144,580
