Could someone please tell me why this script doesn't run correctly. Seems to be a problem with the if statement as i keep getting the error:
/home/sinttx/Development/backup/ddbackup.sh: line 18: syntax error near unexpected token `then'
/home/sinttx/Development/backup/ddbackup.sh: line 18:  if [ "$exit" -eq 0 ] ; then'
The script:
#!/bin/bash
#(SINTTX) Function and if statement to backup/clone /dev/???.
 echo "
 THIS WILL COMPLETE A BACKUP OF DESIRED /DEV "
 echo -n "Enter desired name for saved file (File will be saved with extention .iso) and press [ENTER]: "
 read iso
 echo -n "Enter the device to be duplicated/backed up (Eg /dev/sda) and press [ENTER]: "
 read dev
 echo -n "Enter the desired path/location for the backup file (Eg /home/USERNAME/backups/) and press [ENTER]: "
 read path
 echo "PLEASE ENTER THE SUDO PASSWORD (IF PROMPTED) AND WAIT :-)
 NOTE: THIS COULD TAKE SOME TIME DEPENDING ON FILE SIZE AND HARDWARE SPEED!!"
 sudo dd if="$dev" of="$path"/"$iso"
 exit=$?
  echo "SUCCESS"
 else
  echo "BACKUP HAS SUFFERED AN ERROR AND DID NOT COMPLETE SUCCESSFULLY"
fi
sinttx
  • 31
As @Cyrus suggested, you probably have a non-printing character there that is causing you problems. The most likely reason is that at some point you edited this script from a Windows machine and a \r was added to the end of the line. You can check if anything is there on that line by running
grep 'if [ "$exit"' script.sh | od -c
That will show all characters, including non-printing ones.
If you do indeed have a \r there, you can fix it by running"
sed -i 's/\r//' script.sh
Or, installing dos2unix (sudo apt-get install dos2unix) and running
dos2unix script.sh > fixed.sh
terdon
  • 104,119
