Tech specs: Intel® Xeon(R) CPU E5420 @ 2.50GHz × 8 , 32GB Memory, ubuntu 14.04 (64bit).
HP 5660 envy aio
richard@Doc:~$ cd Desktop
richard@Doc:~/Desktop$ sh hplip-3.14.10.run
Creating directory hplip-3.14.10
Verifying archive integrity... All good.
Uncompressing HPLIP 3.14.10 Self Extracting Archive...........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
HP Linux Imaging and Printing System (ver. 3.14.10)
HPLIP Installer ver. 5.1
Copyright (c) 2001-13 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Installer log saved in: hplip-install_Fri-10-Oct-2014_20:18:49.log
note: Defaults for each question are maked with a '*'. Press <enter> to accept the default.
INSTALLATION MODE
Automatic mode will install the full HPLIP solution with the most common options.
Custom mode allows you to choose installation options to fit specific requirements.
Please choose the installation mode (a=automatic*, c=custom, q=quit) : a
Initializing. Please wait...
INTRODUCTION
This installer will install HPLIP version 3.14.10 on your computer.
Please close any running package management systems now (YaST, Adept, Synaptic, Up2date, etc).
DISTRO/OS CONFIRMATION
Distro appears to be Ubuntu 14.04.
Is "Ubuntu 14.04" your correct distro/OS and version (y=yes*, n=no, q=quit) ? y
ENTER USER PASSWORD
Please enter the sudoer (richard)'s password:
INSTALLATION NOTES
Enable the universe/multiverse repositories. Also be sure you are using the Ubuntu "Main" Repositories. See: https://help.ubuntu.com/community/Repositories/Ubuntu for more information. Disable the CD-ROM/DVD source if you do not have the Ubuntu installation media inserted in the drive.
Please read the installation notes. Press <enter> to continue or 'q' to quit:
RUNNING PRE-INSTALL COMMANDS
OK
INSTALL MISSING REQUIRED DEPENDENCIES
warning: There are 5 missing REQUIRED dependencies.
note: Installation of dependencies requires an active internet connection.
warning: Missing REQUIRED dependency: cups-devel (CUPS devel- Common Unix Printing System development files)
warning: Missing REQUIRED dependency: libusb (libusb - USB library)
warning: Missing REQUIRED dependency: libtool (libtool - Library building support services)
warning: Missing REQUIRED dependency: cups-image (CUPS image - CUPS image development files)
warning: Missing REQUIRED dependency: libjpeg (libjpeg - JPEG library)
INSTALL MISSING OPTIONAL DEPENDENCIES
warning: There are 4 missing OPTIONAL dependencies.
warning: Missing REQUIRED dependency for option 'network': libcrypto (libcrypto - OpenSSL cryptographic library)
warning: Missing REQUIRED dependency for option 'network': libnetsnmp-devel (libnetsnmp-devel - SNMP networking library development files)
warning: Missing REQUIRED dependency for option 'fax': dbus (DBus - Message bus system)
warning: Missing REQUIRED dependency for option 'scan': sane-devel (SANE - Scanning library development files)
CHECKING FOR NETWORK CONNECTION
Network connection present.
RUNNING PRE-PACKAGE COMMANDS
sudo dpkg --configure -a (Pre-depend step 1)
sudo apt-get install --yes --force-yes -f (Pre-depend step 2)
sudo apt-get update (Pre-depend step 3)
OK
DEPENDENCY AND CONFLICT RESOLUTION
Running 'sudo apt-get install --assume-yes libcups2-dev'
Please wait, this may take several minutes...
Running 'sudo apt-get install --assume-yes cups-bsd'
Running 'sudo apt-get install --assume-yes cups-client'
Running 'sudo apt-get install --assume-yes libusb-1.0.0-dev'
Running 'sudo apt-get install --assume-yes libtool'
Running 'sudo apt-get install --assume-yes libcupsimage2-dev'
Running 'sudo apt-get install --assume-yes libjpeg-dev'
Running 'sudo apt-get install --assume-yes openssl'
Running 'sudo apt-get install --assume-yes libsnmp-dev'
Running 'sudo apt-get install --assume-yes snmp-mibs-downloader'
Running 'sudo apt-get install --assume-yes libdbus-1-dev'
Running 'sudo apt-get install --assume-yes libsane-dev'
HPLIP-3.14.3 exists, this may conflict with the new one being installed.
Do you want to ('i'= Remove and Install*, 'o'= Overwrite, 'q'= Quit)? :i
Starting uninstallation...
HPLIP uninstallation is completed
RUNNING POST-PACKAGE COMMANDS
OK
RE-CHECKING DEPENDENCIES
PRE-BUILD COMMANDS
OK
BUILD AND INSTALL
Running './configure --with-hpppddir=/usr/share/ppd/HP --libdir=/usr/lib --prefix=/usr --enable-udev-acl-rules --enable-qt4 --disable-libusb01_build --enable-doc-build --disable-cups-ppd-install --disable-foomatic-drv-install --disable-foomatic-ppd-install --disable-hpijs-install --disable-udev_sysfs_rules --disable-policykit --enable-cups-drv-install --enable-hpcups-install --enable-network-build --enable-dbus-build --enable-scan-build --enable-fax-build'
error: Configure failed with error: python-devel not found
richard@Doc:~$ sudo apt-get install python-devel
Reading package lists... Done
Building dependency tree
E: Unable to locate package python-devel
