I come from a Windows world where Chrome automagically updates itself without any intervention (other than the occasional browser restart, since I leave my browser open all the time.)
In Ubuntu, I frequently notice Chrome listed in Update Manager. I don't recall if I installed Chrome through apt-get or not.
Why does Chrome rely on apt-get for updates? Is there a way to have a "Windows-like" experience where it updates itself without my intervention? This is my goal.
Braiam
  • 69,112
ashes999
  • 177
As parto said, you can just make it update in the background. To do that here are two options:
  1. Make a startup script that runs as root (see here: How to run a script during boot as root) with the contents
apt-get upgdate && apt-get upgrade chromium -y
You may need to change the name of chrome to whatever the package name actually is.
  1. You can do the same thing with a cron job, and run it as root (see here: https://stackoverflow.com/questions/1015485/is-it-possible-to-make-a-bash-file-run-as-root-in-crontab) with the same contents
Also, Rinzwind has a good point in the comments - you're likely using chromium as Google Chrome doesn't use apt
Mitch
  • 4,807
No, there is not a way to get the "windows-like" experience of having Google Chrome "update itself."
apt-get is the cleanest and most well-integrated (from OS perspective) of managing updates for your system.
apt-get also affords the system admin a good "one stop shop" for controlling versioning and updates. For these reasons, Google made the design choice to have automatic updates be ran by apt-get for the simplicity and convenience of the user.
MGodby
  • 1,172
Chrome adds it's own repository on install. On https://www.google.com/chrome/browser/ it states:
Note: Installing Google Chrome will add the Google repository so your system will automatically keep Google Chrome up to date. If you don’t want Google's repository, do “sudo touch /etc/default/google-chrome” before installing the package.
So unless you do that before you install it should add a repository that will keep Chrome up to date with the system upgrades.
Picture of my sources after deb install:
So yes you will get updated versions of Chrome when doing updates. (either through Software Updater or apt-get update and apt-get upgrade)
So no intervention required if just do your updates like normal, I suggest letting it do them daily, as the update process is less intensive with only a handful at a time, and there are no forced restarts, and the old version of a program can stay in memory while it is currently being updated - so it is be perfectly fine to have programs open while they are being updated.
Mateo
  • 8,152
