14
When I play a .webm file using the VP9 codec in VLC, I get the following error message (and the audio is played):
VLC does not support the audio or video format "VP90". Unfortunately there is no way for you to fix this.
I can play these files in totem, but how can I play them in VLC?
I'm on Ubuntu 14.04 and VLC is 2.1.6. The package ubuntu-restricted-extras is installed.
Joschua
  • 345
VP9 requires VLC 2.2.
sudo add-apt-repository ppa:mc3man/trusty-media
sudo apt-get update
sudo apt-get install vlc vlc-plugin-*
https://forum.videolan.org/viewtopic.php?t=131211
I had this problem in ubuntu 14.04 and it got solved by installing VLC 2.2.
There is no need to install ubuntu-restricted-extras to be able to play WebM with VLC. VLC 2.1.2 supports VP9 by default (see http://www.webmproject.org/vp9/ and http://www.videolan.org/vlc/releases/2.1.2.html). You might try upgrading VLC or installing the latest stable by downloading it from the VLC site directly.
Karl Wilbur
  • 1,975
I've had to apt remove vlc-? before I found out that something from that package was playing havoc with HTML5 video ('vp9' codec)/DASH accelerated video rendering/streaming in Firefox.
You may need to install restricted extras:
sudo apt-get install ubuntu-restricted-extras
That should work. But if it doesn't work after installing ubuntu-restricted-extras
Open Ubuntu Software center and search for "gstreamer" and install it.
Or open the terminal and type the following commands:
sudo add-apt-repository ppa:gstreamer-developers/ppa
sudo apt-get update
sudo apt-get install gstreamer1.0*
I hope that helps.
