I have tried sudo apt-get autoclean and sudo apt-get clean. Still I keep getting this error
I am running Ubuntu 12
siddharth@IWORKHERE:~/Downloads$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
openjdk-7-jdk
Suggested packages:
visualvm
The following packages will be upgraded:
openjdk-7-jdk 1 upgraded, 0 newly installed, 0 to remove and 89 not upgraded.
Need to get 0 B/16.5 MB of archives.
After this operation, 88.1 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
(Reading database ... 394130 files and directories currently installed.)
Preparing to replace openjdk-7-jdk 7u55-2.4.7-1ubuntu1~0.12.04.2 (using .../openjdk-7-jdk_7u65-2.5.1-4ubuntu1~0.12.04.2_i386.deb) ...
Unpacking replacement openjdk-7-jdk ... dpkg: error processing
/var/cache/apt/archives/openjdk-7-jdk_7u65-2.5.1-4ubuntu1~0.12.04.2_i386.deb (--unpack):
trying to overwrite '/usr/lib/jvm/java-7-openjdk-i386/src.zip', which is also in package openjdk-7-source 7u55-2.4.7-1ubuntu1~0.12.04.2
Errors were encountered while processing: /var/cache/apt/archives/openjdk-7-jdk_7u65-2.5.1-4ubuntu1~0.12.04.2_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
