13
Content of my filename file is as following(for example):
My block of line starts from here
START
First line
second line
third line
END
and end to here for example.
I want to replace block of lines between START and END with just a single word, for example with SINGLEWORD. Like below:
SINGLEWORD
I can find my block of lines with using this command:
grep -Pzo "START(.|\n)*END" filename
And the result of running above command will be like this:
START
First line
second line
third line
END
Then I used this command to combine all lines into a single line:
LAST_RESULT | sed -e :a -e '/$/N; s/\n/ /; ta'
Then I will get this result:
START First line second line third line END
And with my last command LAST_RESULTS | sed 's/.*/SINGLEWORD/' I change them to "SINGLEWORD" and I get this result.
SINGLEWORD
Now what I want is: How can I use this command(Or your suggestion command) and replace(in place)my block of lines to "SINGLEWORD" word? And the final result will be like this file:
SINGLEWORD
αғsнιη
  • 36,350
This can be done very easily in perl:
$ perl -i -p0e 's/START.*?END/SINGLEWORD/s' file
$ cat file
SINGLEWORD
Explanation
-0 sets the line separator to null
-p apply the script given by -e to each line and print that line
The regexp modifier:
  • /s Treat string as single line. That is, change . to match any character whatsoever, even a newline, which normally it would not match.
Why the ?:
  • By default, a quantified subpattern is "greedy", that is, it will match as many times as possible (given a particular starting location) while still allowing the rest of the pattern to match. If you want it to match the minimum number of times possible, follow the quantifier with a ?.
14
I was wondering if this is possible without perl, python and others. And I found this solution using sed:
$ sed ':a;N;$!ba;s/START.*END/SINGLEWORD/g' filename
Explanation:
  1. :a create a label 'a'
  2. N append the next line to the pattern space
  3. $! if not the last line, ba branch (go to) label 'a'
  4. s substitute, /START.*END/ by SINGLEWORD,/g global match (as many times as it can)
It was found here.
αғsнιη
  • 36,350
c0rp
  • 10,010
While ripgrep specifically doesn't support inline replacement, I've found that its current --replace functionality is already useful for this use case:
rg --replace 'SINGLEWORD' --passthru --no-line-number \
--multiline --multiline-dotall 'START.*?END' input.txt > output.txt
Explanation:
  • --replace 'SINGLEWORD' enables replacement mode and sets the replacement string. Can include captured regex groups by using $1 etc.
  • --passthru is needed since ripgrep usually only shows the lines matching the regex pattern. With this option it also shows all lines from the file that don't match.
  • --no-line-number / -N is because by default ripgrep includes the line numbers in the output (useful when only the matching lines are shown).
  • --multiline / -U enabled multiline processing since it's disabled by default.
  • --multiline-dotall is only needed if you want the dot ('.') regex pattern to match newlines (\n).
  • > output.txt is needed since inline replace isn't supported. With the --passthrough and no-line-number options the standard output matches the desired new file with replacements and can be saved as usual.
However, this command isn't as useful for processing multiple files, as it needs to be run separately per file.
Silveri
  • 299
