Last day I saw this error:
 “The system is running in low-graphics mode”
I tired some methods to fix but didn't worked for me so I re-installed ubuntu.
I just installed few apps today and everything was working fine... but now I see again this error message.
I have tried some methods from askubuntu and ubuntuforums but none of theme was not working for me.
Here you can see my Graphic details:
I dont have nvidia graphics! https://i.sstatic.net/Fr5UQ.jpg
What should i do?
Seth
  • 59,332
thumper2
You can try and turn off the switchable graphics in the BIOS:
Reboot your computer, enter the BIOS settings and change them from:
  • switchable graphics
  • Hybrid graphics
to:
  • UMA graphics
  • On-board graphics
  • Intel Graphics
    after that, it will be possible to use the Intel video card only with proper drivers on Ubuntu.
Here is the source of my material
I've had this problem in the past with my NVidia graphics card. I don't know if there is something similar for your Lenovo system. For what it's worth, since there may be others with NVida problems, here is what I do/did:
  1. Log out of X: sudo /etc/init.d/gdm stop Screen will go black with the last white messages from bootup.
  2. will give you a login prompt. Log in to get a command line prompt.
  3. sudo su, cd to /root, then execute: ./NVIDIA-Linux_x86_169.12-pkg1.run (Tab key will allow auto completion -- the version numbers may have changed.) This will give a screen-app with prompts for you to follow:
    Accept license (need to make it white highlighted)
    Allow removal of previous 169.12
    Allow it to go to web for a new version of something.
    Allow it to rebuilt the X configuration file.
    Accept the "OK" when it says it is done.
This will return you to the command line prompt.
  1. (Still as root from above su): 'reboot'
Richard Silbar
  • 217
