22
recently I installed nemo as default filemanager replacing the nautilus. So far it work perfectly except the fact that I missed the "right click extract/compress". I've installed nemo 2.2.2 and nemo-fileroller through apt-get command on Ubuntu 14.04.
How can I have the right click menu for to "extract/compress"?
NinoDenero
  • 321
Very simply, all you should need to do is install the nemo-fileroller package:
sudo apt-get install nemo-fileroller
To apply the changes quit the file-manager with
nemo -q
to then (re-)start it like you normally would.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Wilf
  • 30,732
19
Okay, I've tried lots of "solutions" but none of them work, so I went and dug out how things work, and here's how I did it on Ubuntu 14.04 and Nemo 2.2.2...
  1. Open up terminal and type cd ~/.local/share/nemo/actions/
  2. Create a new file/action for Compress by typing nano compress.nemo_action
  3. Paste this contents into newly created file
    [Nemo Action]
    Active=true
    Name=Compress...
    Comment=compress %N
    Exec=file-roller -d %F
    Icon-Name=gnome-mime-application-x-compress
    Selection=Any
    Extensions=any;
  4. Save the file and exit (CTRL+X, and just Enter)
  5. Create a new file/action for "Extract here" by typing nano extracthere.nemo_action
  6. Paste this contents into newly created file
    [Nemo Action]
    Active=true
    Name=Extract here
    Comment=Extract here
    Exec=file-roller -h %F
     #Stock-Id=gtk-cdrom
    Selection=Any
    Extensions=zip;7z;ar;cbz;cpio;exe;iso;jar;tar;tar;7z;tar.Z;tar.bz2;tar.gz;tar.lz;tar.lzma;tar.xz;
  7. Save the file and exit (CTRL+X, and just Enter)
  8. You're done. If you still don't have Compress/Extract here options in Nemo, just restart or log out/in.
Creating Nemo actions is the only way I've achieved this, I've tried several repos and tutorial of which none worked.
DJCrashdummy
  • 1,922
dBlaze
  • 341
To improve the Compress/Extract integration, I'm posting an Escape-Safe way (because folders with spaces in the name was crashing my file-roller):
Create the following .nemo_action files and their contents, at /usr/share/nemo/actions:
compress.nemo_action:
[Nemo Action]
Active=true
Name=Compress...
Comment=Compress "%f"
Exec=file-roller --add %F --default-dir=%P
Selection=notnone
Extensions=any;
Quote=double
extract-here.nemo_action:
[Nemo Action]
Active=true
Name=Extract here
Comment=Extract "%f" here
Exec=file-roller --extract-here %F
Selection=notnone
Extensions=zip;7z;ar;cbz;cpio;exe;iso;jar;tar;tar.Z;tar.bz2;tar.gz;tar.lz;tar.lzma;tar.xz;
Quote=double
extract-to.nemo_action:
[Nemo Action]
Active=true
Name=Extract to...
Comment=Extract to a folder of your choice.
Exec=file-roller --extract %F
Selection=notnone
Quote=double
Maxwel Leite
  • 2,424
Matt Mello
  • 433
  • 13
I believe the above nemo actions is missing the "Quote=double" parameter otherwise files/directories that have space(s) in their name won't work. e.g.
[Nemo Action]
Active=true
Name=Compress...
Comment=compress %N
Selection=any
Extensions=any;
Quote=double
Also useful is an "Extract to..." action, which allows you to select a different path where you may want to extract the files to.
e.g.
extractto.nemo_action
[Nemo Action]
Active=true
Name=Extract to...
Comment=Extract to...
Exec=file-roller -f %F
#Stock-Id=gtk-cdrom
Selection=any
Quote=double
mpham
  • 51
