I've installed ubuntu 14.04 along with windows 8.1. After installing ubuntu I'm unable to boot windows and unable to mount my 222 GB volume. I got following error when i tried to mount my 222 GB volume:
Error mounting /dev/sda4 at /media/ankit/4EA0C653A0C64167: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sda4" "/media/ankit/4EA0C653A0C64167"' exited with non-zero exit status 12: Failed to read last sector (495691775): Invalid argument
HINTS: Either the volume is a RAID/LDM but it wasn't setup yet, or it was not setup correctly (e.g. by not using mdadm --build ...), or a wrong device is tried to be mounted, or the partition table is corrupt (partition is smaller than NTFS), or the NTFS boot sector is corrupt (NTFS size is not valid).
Failed to mount '/dev/sda4': Invalid argument
The device '/dev/sda4' doesn't seem to have a valid NTFS.
Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
Private
  • 4,074
Ankit
  • 111
