I have a laptop which I have two different HDs (SATA-II 2.5"), one for Vista (i know) and the for Ubuntu 14.04.
Ordinarily, I actually swap over the drives in the laptop's internal bay when I want switch systems. It was a way of giving me guaranteed integrity of the Vista system.
I now have a caddy that meanns I could - if it were possible - run them as a dual boot.
My question: Is it possible to make a dual boot from this configuration? And, can I put either into the internal bay, or is it going to have to be vista?
Thanks in advance.
garrilla
  • 115
But of course! You will need some special tweaking, though.
If you have a uEFI system, simply install something like rEFInd. It will allow you to choose whether to boot into vista or Ubuntu. Don't hotswap drives, though. Keep one in the caddy, and make sure it stays there.
If you have Legacy BIOS, it gets a bit trickier. You need to go into your BIOS settings and figure out how to select a one-time boot device. Once you have found that, place the Vista hard drive in your PC, and the Ubuntu drive in the caddy. Use BIOS to select the specific drive, and voila!
The reason I had you stay away from GRUB is because it'll not find what it wants (Linux) if the Windows drive is internal. Conversely, Windows won't work too well if it's not internal. It's very picky about hardware...
Kaz Wolfe
  • 34,680
