Help I want to install Ubuntu 14.04 LTS on my desktop beside windows XP but I want to be sure whether the hardwares are supported (I think it is non-Pae) My Desktop spec is:
CPU Type: Intel Celeron D 325, 2533 MHz (19 x 133)
Motherboard Name: MSI 865PE Neo2-PS (MS-6728 v2.0)  (5 PCI, 1 AGP, 4 DDR DIMM, Audio)
BIOS Type: AMI (09/29/04)
Display:
Video Adapter: NVIDIA GeForce4 MX 4000 (Microsoft Corporation)  (128 MB)
Motherboard Properties:
      Manufacturer: MICRO-STAR INC.
      Product: MS-6728
      Version: 2.00
Rams: 2 * 512 MB = 1000 MB Memory Type: DDR SDRAM Memory Speed: PC3200 (200 MHz)
I need the best way to use if possible so not to lose Win xp Any help would be appreciated Thanks in advace
user68186
  • 37,461
Real Dysky,
You can run Ubuntu 14.04.1 LTS without install it. During boot,the first question is if you want to install or run an instance to test it, then you can certify the compatibility of hardware before install it.
I hope that this procedure gives you the security required for a definitive installation.
kind regards and success!
Fernando Santucci
  • 1,290
  • 19
