220
I have written the following script to set some environment variables when needed:
#!/bin/sh
export BASE=/home/develop/trees
echo $BASE
export PATH=$PATH:$BASE
echo $PATH
Below the command and the results I can see on my terminal: the script runs, but the variables are not set at the end.
~$: ./script.sh
/home/develop/trees
/bin:......:/home/develop/trees
~$: echo $BASE
What is wrong?
vvvvv
  • 878
MirkoZa
  • 2,311
export exports the variable assignment to child processes of the shell in which the export command was ran. Your command-line environment is the parent of the script's shell, so it does not see the variable assignment.
You can use the . (or source) bash command to execute the script commands in the current shell environment and achieve what you want, e.g.
source ./script.sh
echo "$BASE"
Will produce
/home/develop/trees
The source command, often seen in scripts, is a bash synonym for ., which is part of the POSIX standard (so . is available in dash, for example, but source isn't).
. ./script.sh     # identical to "source ./script.sh"
(. script.sh and source script.sh will first look for script.sh in PATH, so it's safer to specify the path to script.sh.)
muru
  • 207,228
26
When you run a script, it runs in a subshell. Variables are only valid within the context of that subshell. Set them in your .bashrc or .profile and read up on variables and subshells. The export statement works down hierachy (current shell and all it's subshells) not up as in your example.
Alternatively (if you really want the script to effect the enviroment of your current shell) run it as:
. ./script.sh
That causes it to run in your current shell but will not pass variables up the hierarchy either.
Elder Geek
  • 36,752
con-f-use
  • 19,041
I often want to set an environment variable without hassle.
Here is what I add to my .bashrc to implement this convenience.
defect() {
    if [ $1 ] && [ -z $2 ]
    then
        eval 'export DEFECT=$1'
        return 0
    else
        echo 'Usage: defect {number}'
        return 1
    fi
muru
  • 207,228
jlettvin
  • 181
