I dont have the send to option when right click a file and the files are greyed out so am unable to select when trying to copy? please help it was fine before the 14.04 update.
The problem is, you are not the root user. Follow the instructions below:
Press Ctrl+Alt+T
Type in the following command and press enter:
sudo nautilusSelect a file that you want to transfer and send (right click on file, Copy To...) it to any particular location (including, USB).
OR
Follow this:
Press, Ctrl+Alt+T
Use this:
cp source-address-of-file-including-file destination-addressIn your case:
cp /home/username/your-file-name.txt /media/username/your-media-name/
- 594
I think you should give it a try and copy/paste or move the files within Terminal.
If not you're not handy with Terminal , its about time mate!
I practically do Everything in terminal after several pumps.
- 21
Try using another file manager, like PCManFM:
sudo apt-get install pcmanfm
Start it from the dash. You should be able to copy the files you want.
- 1,091
