-1
I have ubuntu 12.04 LTS and I do not know my authentication password due to which i cannot install any software. Its urgent. Please tell me a solution and not a suggestion. In case , if I have set the password and forgotten it, what do I do to remove the existing password?
"Boot up the machine,and after the BIOS screen, hold down the left Shift key." Did indeed NOT log you into the machine. That is correct. You are seeing a menu instead. If not, then don't read any further and try again.
If you do see the menu: Choose "Advanced options", then choose (recovery) from the menu. Then you see a lot of text passing upward on the screen. Do nothing. Then you see a colored menu. Choose "root".
Type:
mount -o remount,rw /
passwd your_username_here
change your password
then type:
reboot
Source of Screenshots
Pert8S
  • 676
