Is there any way to just download all Ubuntu repositories using apt-get? I am looking for something like :
sudo apt-get install --download-only *
So that I can access the downloaded repository in the directory /var/cache/apt/archives/.
Pandya
  • 37,289
Nejat
  • 235
First of all, this is not a convenient way. Instead of this you should use the method mention here. But as an answer to the question.
  • First create a file which contains names of all the available packages using apt-cache.
    apt-cache  dumpavail |grep -oP "(?<=Package: ).*" >> packagelist
    This will create a file packagelist with all the available packages.
  • Now create a simple script to download all the packages present in the file packagelist
    #!/bin/bash
    for package in `cat packagelist`
     do
        apt-get install -y --download-only $package
     done
  • Save it.
  • Make it executable using
    chmod +x your_script_name
  • Now open terminal and login as root
    sudo -i
    cd /folder/of/you/script
    ./you_script_name
It will download all the available package depending upon your /etc/apt/sources.list in /var/cache/apt/archives directory
g_p
  • 19,034
  • 59
  • 69
You can use a tool called apt-cacher. You can check this link for more info. Hope it helps.
