Is it a GPG key or a PGP key? Or do you just use gpg to produce the pgp key?
I see them used together, and its just a tad bit confusing. What do they stand for?
The standard is "PGP" and the key is called a PGP key.
GPG stands for GnuPG, which is Gnu's implementation of the Open PGP standard.
"GPG Key" and "PGP Key" are effectively the same thing.
In the beginning (1991), there was PGP (= Pretty Good Privacy). It was an encryption software that could not be used outside the USA, due to export restrictions.
When the software finally became available internationally, it became a de-facto standard which later evolved into RFC 2440 (and RFC 4880 subsequently).
GPG (= GNU Privacy Guard) implements said RFCs and as such, is able to use PGP keys.
