Title says it all, every time I shut down I have to rerun xinput --set-prop 11 "Synaptics Finger" 10 15 100 again is there any way to fix this?
Asked
Active
Viewed 7,551 times
Volker Siegel
- 13,295
Tad Kozusko
- 21
- 1
- 2
I had the exact same issue. As an alternative to Humpity's answer, I just made a shell script saved in my home directory then added it to my Startup Applications list.
"Startup script.sh":
#!/bin/bash
xinput set-prop "appletouch" "Synaptics Finger" 10, 20, 100
Then open the Startup Applications GUI (which should be installed by default in ubuntu) and add a new entry to the list with the command field like so:
"/home/user_name/Startup script.sh"
Put a command inside a .desktop file
[Desktop Entry]
Type=Application
Name=USER autostart
Comment=my commands after X startup
Exec=<your command>
And save it as [your-home]/.config/autostart/user-autostart.desktop This will execute when X starts.
Humpity
- 188
- 13
