Few days ago I updated my laptop from 13.10 to 14.04 by reinstalling everything and I started having troubles with my Broadcom card. It was working well with previous version, so i don't know what is going wrong now.
By following wiki pages and other answers here is what i did:
  • found out my model, which is BCM43228 14e4:4359
  • installed dkms and bcmw-kernel-source from installation cd
At this point if I check with lsmod I see that module wl, which should be the one used by my card, is correctly loaded. I am able to connect to my network (after about 15 seconds), but the connection is extremely slow (can't even perform an apt-get update till the end).
What elese could I try? I need my laptop for my courses, so I would like to fix this issue as soon as possible. Thank you in advance.
Pyrox
  • 121
I'm having the same problem and I'm about to try installing b43. Only do this if you are sure because I'm a total newb and I don't know what I'm talking about really. But basically I think this is an open source version. And that should be better because the developers can test and modify the drivers. Here is a guide to installing: http://www.howopensource.com/2012/10/install-broadcom-b43-legacy-wireless-driver-in-ubuntu-12-10-12-04/
If you haven't already read this: https://help.ubuntu.com/community/WifiDocs/Driver/bcm43xx
Here is a totally different idea (rolling back the driver): How to downgrade Broadcom wireless drivers bcmwl-kernel-source?
